Modifying special shortcuts
Command |
Path |
Edit Current Workspace |
Tools > Workspaces |
You can modify the keyboard shortcuts for switching between modes on the Tool bar, for activating snapping functionality, and other special features.
Vectorworks remembers whether a numerical shortcut key is entered using the number key pad or the number row above the letters. A notation of "Num" indicates the number pad is used for the shortcut.
To modify special shortcuts:
Select the command; the Workspace Editor dialog box opens to the selected workspace.
If you need to edit a different workspace, select it in the Workspace list.
Click the Keys tab to display the keyboard shortcuts for the workspace currently in use, and modify the assigned shortcut keys.
Parameter |
Description |
Mode Groups |
Sets the shortcut keys to switch modes for the active tool; the key in 1 controls the first mode group, the key in 2 controls the second mode group, and so on |
Other Keys |
Sets the keyboard shortcuts for the functions below |
Toggle SmartCursor Cues |
Press this key to toggle on and off the SmartCursor cue display |
Toggle Angles Relative To Prior Segment |
Press this key to toggle whether angle snaps are set relative to the axes or to the previously drawn segment |
Set Datum |
Press this key to create a datum point for snapping at the current cursor location |
Snap Loupe |
Press this key to open the Snap Loupe window |
Set Smart Point, Edge, or Vector Snap Lock |
Press this key to set a smart point, smart edge, or vector snap lock at the current location |
Toggle Automatic Working Plane |
Press this key to toggle on and off the automatic working plane functionality; see Using working planes |
Suspend Snapping |
Press and hold this key to disable snapping temporarily; double-click this key to make the suspension stick, and then to enable snapping again |
X-ray Select Mode |
Press and hold this key to see and select objects that are normally obscured behind 2D object fills or 3D rendered objects; see X-ray Select mode |
Coincident Selection |
If the cursor is over multiple objects at the current location, press and hold this key and click to open a dialog box from which you can select one or more of the objects; see Coincident object selection |
Close Polygon, Polyline, Wall Network or Path Objects |
After completing all but the final click, press the keyboard shortcut to automatically close polygon, polyline, polygonal wall network, or path-based objects |
Toggle Multiple View Panes |
Press this key to toggle on and off the display of multiple view panes |
Trigger Smart Options Display |
If desired, assign a shortcut to toggle on and off Smart Options Display in the drawing area; Use Smart Options Display must be selected on the Smart Options Display pane of the Vectorworks Preferences dialog box |
Launch Quick Search |
Press this key to open the quick search window |
Repeat Last Command |
Press this key to repeat the most recent command |
Toggle Show Hidden Objects as Ghosted |
Press this key to toggle between hidden objects being fully hidden or "ghosted" (transparent with a light blue tint) |
Snapping Keys |
If desired, assign keyboard shortcuts to toggle each snapping tool. Double-tap the snapping shortcut key (for snapping tools that have an arrow in the lower-right corner) to open a popover with settings for that snapping type. |
